Gages are not coming on
Melissa Hall
turned power on and gages are not coming on and Garmin isn't either. Changed the fuzes out in the battier compartment and still nothing
Check connections to the battery. Try turning the boat over to see if it will start. Do you charge your battery while not on the water?
motor will start and no I do not charge the batteries
Your house battery is probably dead or has a loose connetion. The guages and connext all run off the house battery.
