PortTobacco II
Jetboaters Commander
- Southern Maryland
- SX
I recently installed my Garmin and am pretty happy with my approach. I purchased a RAM Mount with an 11" arm and 1.5 " ball mount base. I screwed the ball mount base to wall next to the gauges. I used 3 stainless steel bolts for the ball mount base. Thought the wall was a little thin, so I reinforced it will a piece of plastic cutting board that I cut to the size I need. The cutting board was strong plastic and cut it as large as I could. I used a generous amount of that 3M marine grade epoxy and let dry/cure for a few days before drilling holes for my bolts.
Over all very happy with the install. It allows of tons of different positioning of the Garmin. It does block my view and I get it completely out of the way when I need to.
One thing I still to figure out is the power. For now, I am using the power that would go to the 12amp aux plug on the dash. So that plug does not work at all but my Garmin does. I will figure the wiring out at some point so that everything works.
