Grover70
- Ponte Vedra, FL
- FSH Deluxe
Okay, ignoring the 5200 all over the transducer from a previous in-hull placement, it is now mounted where you see it. I took it out yesterday and got clean readings all around...until I hit 20 knots. I'm assuming this is turbulence from the first step just forward? So, my question is: Do you lower the transducer a little more to get it past the assumed turbulence from that first step to get it deeper into the non-turbulent water...or...do you add a separate depth finder only and just accept the fact you can't get depth readings and other capabilities over 20 knots?
Thanks!
Thanks!
