RBuffordTJ
- SR
I have a 2005 SX230 with the port engine surging from 3000rpm to 5000rpm maxing out at 8k.
I serviced both engines but the port is the problem child. Both were overfilled with oil thanks to a dealer here locally so I drained it down and changed the plugs.
PROBLEM: #1 cylinder on the port engine is the problem. Lots of gas in the water behind the boat. Pulled the plug it is soaked with gas.
I ordered a YDS system and i am awaiting its arrival to try and test the injector. Any suggestions on what I can do in the meantime? I read @bronze_10 post and think I may have a similar issue. Stuck injector.
My other thought is maybe the ECU but praying not.
Any suggestions are appreciated .
Rick in SC
Rick in SC
