WTScott
- 242 Limited E-Series
Hey team,
New install of Lowrance Elite Ti 9 inch on my FSH 210 and having some intermittent connection problems. This is my second boat with this install and no problems on first one.
The signal will get intermittent after a run on the lake or hitting bumps. Most of the time it is solved shaking the cable / connector in the back of the unit. I have reset the cable several times. Wanted to see if anyone had a simple solution before starting the troubleshooting with Lowrance.
Thanks
Thanks
