SWAG GPS Antenna Cover Replacement - Red JetBoaters.net Logo
  • Thread starter Thread starter Bruce
  • Start date Start date
  • Quantity Qty: 994
This is a replacement cover for Yamaha part number F2D-U8K1L-00-00 also known as SANAV part number GM-88U.
It is a new design that includes an optional external seal. If you do not wish to use the external seal it is recommended to use silicone caulk to seal between the plastic case sections and around the heads of the screws. It is printed from PETG plastic which should hold up well to sun exposure and resist impact.
Click the green "Buy now" button in the top right hand corner to order.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
@Bruce , Love the idea and design ! Is it going to be available in any colors other than red ? Maybe the same blue that you used for the steering bushings ?
Just ordered a replacement over to replace my cracked antenna. Rigged it to go out on the boatDC435843-01ED-4C3F-954A-068C6BCAED51.jpeg
Just ordered a replacement over to replace my cracked antenna. Rigged it to go out on the boatView attachment 196020
I will get it in the mail tomorrow morning but rather than wrapping the damaged unit I would remove the electronics until you are ready to install the new cover. There is an electrical connecter that disconnects and the ground wire which I do not believe it connected on the boat side. You have to cut then splice the ground wire when you reassemble.
