Seattle-Wind
We have a brand new '19 Yamaha AR190 and it appears that Yamaha has changed the service recommendation for greasing the intermediate bearing, per the owners manual. I've always read that this is a 10 hour service, but the owners manual says to grease the intermediate bearings every 100 hours or 12 months (see photos) and it's not listed as a 10 hour service item. Does the boat come with greased intermediate bearings now whereas they used to come dry or with minimal grease?
Also, it appears that the boat now has a zirk fitting on top of the engine with a hose leading to the zirk fitting on top of the housing itself (see photos), rather than only a zirk fitting on top of the housing. I've read that pumping grease into the zirk can lead to busted seals and instead I should unscrew the zirk fitting on the housing and syringe in some grease. Does anyone have comments or confirmation on that procedure?
