Ground Strip on 2022 AR 250
anjboyer
Is there a common ground block under the helm of a 2022 AR 250? If so, where is it located.
No. If your batteries are on the same place as the 252 open the hatch and look at the fire wall theres the grounding block. Same side as the batteries
Thank you. Adding an amp under helm and was hoping I did not have to run a separate ground cable back to battery area.
