GTS207 no crank
Hiltonb
Glastron
GTS
Good afternoon all,
We have a 2014 GTS207 new to us. We rolled it out today and have been preparing for the lake. However we have an issue. We have no crank, no radio. The dash comes on with an audible beep (but sometimes have to wiggle the key to get that). I do not hear the pump coming on. Could this be a simple ignition key issue? Please advise on your thoughts.
thank you!
This can be any number of things....
The simplest being that it is not in neutral or the neutral switch is faulty.
One problem that has plagued me in this boat is... that if I forget to completely disconnect the battery it will drain.
Starting this motor on a weak battery will (at least on my 207) will always fry the ignition relay in the fuse panel.
It throws no codes, everything seems fine, I hear the beep but no crank as the same as if its not in neutral.
I went as far as buying a bunch of backup relays, since my battery is always going dead.
Another suggestion - have you tried the emergency disconnect switch? Pull the safety and then reconnect it.
