ReelFishingSWFL
- FSH Sport
I am in possession of a 2017 Yamaha FSH 190 sport, which unfortunately seems to be experiencing a rather peculiar issue. It appears that unless I engage the key halfway, release it, patiently await the computer to initiate its booting process after the audible beep, and only then proceed to turn the key, the engine will start. Should I attempt to turn the key prior to following this specific sequence, the engine will merely struggle to ignite. Consequently, I find myself in the position of having to engage the key halfway, release it, activate auxiliary mode, and subsequently turn it on. I would greatly appreciate any suggestions or recommendations you may have regarding this matter. Thank you! (2 new batteries, new voltage regulator, checked all connections and cleaned any rust)
