Has anyone replaced the connext screen with a larger better option?
Craigmc
Would like a larger screen in place of the 4.3 factory screen anyone done this?
No real options unless you add converters to the output on all the engen sensors as Yamaha is not using standard communication protocals. Many have tried and failed.
replace it with the current connext screen or something aftermarket? I think both would be pretty difficult and expensive.
It would be super nice to be able to replace with a nice simrad or something, but I think it's all too proprietary.
You are pretty much stuck with what you have. Yamaha's stuff is proprietary. Once of the best things they could do is to make it compatible.
I'm wondering if the connext screen is for reporting info, or if there's some need to have it in the mix as well.
If it can't be disconnected, what about simply removing it from the dash and mounting/stowing it in the gunnel area behind the throttles or somewhere similar to where you might mount an extra speaker? Like having it set up as almost an auxiliary screen at your right hand?
At the very least, somewhere just behind the helm, inside the door? Alarms would be a bit more of a PITA there, and I dunno if the cables would allow it to reach close enough to the door opening, but it could remain in play, while still being out of the way
Fabrication of a new panel wouldn't be that hard if you have the proper tools, and if you don't have the tools, you're not likely to be the person looking to attempt this after looking into it.
As the boats age and the connext units start to fail this will create all types of issues somewhere on this world someone or a team designed these things and has all the info of exactly how they work. It sucks that its under lock and key and that info could be so handy I would rather have analog controls for all the items that connext controls. These screens are already becoming a sought after item and after only a few years are not available from Yamaha.
Apple's planned obsolescence model, on items costing multi tens of thousands of dollars.
This became clear to the average Joe, finally, when cars couldn't be bought due to the "supply chain". My current car was sought by me precisely because it didn't come with the in-dash map/control display. The maps won't be updated after a while, and if there's another issue with the screen, heat, a/c, radio, maps, etc are rendered useless, with the repair screen costing a thousand or more just to have a car with operable functions that used to be handled by a $5-50 switch that didn't disrupt 12 other functions.
Someone will come up with a workaround, but the person with an itch to upgrade will pass
I went with just adding a tablet as a second screen on my 212S. Works nice for playing music and navigation with the navionics boating app. Used 2 suction window mounts to do it as a no drill option. Fits over the existing cell phone mount. Screenshot_20230818-231957.png
I've replaced the USBC cable with a short black u shaped one since this pic so looks more clean.
I went with just adding a tablet as a second screen on my 212S. Works nice for playing music and navigation with the navionics boating app. Used 2 suction window mounts to do it as a no drill option. Fits over the existing cell phone mount. View attachment 206778
To my eye, that's a great upgrade! On my boat, that area has the tachs, and I don't find a need for them, so your idea is even better than moving the Connext screen, as it leaves it accessible to shut off alarms easier than moving it behind the helm would allow.
That might be one to copy, thanks for sharing!
I have a tablet I use as well, with Navionics, but havent mounted it yet, where did you get the suction mounts, and how do they attach to tablet?
I think I got mine at Costco as a 2 pack a while ago. They are Scosche brand Magic Mounts. They can use a adhesive metal plate on the decice, but the Samsung Galaxy Tab S6 Lite I use has either magnets or metal of its own that stick pretty good. Nice part about it being an Android tablet is it has split screen so I have the nav and my music app open in split screen.
This looks like it is the same ones I have...
Scosche MAGWSM-SP1 Magic Mount Magnetic Dash/Window Suction Mount for Mobile Devices Adjustable 360 Scosche MAGWSM-SP1 Magic Mount Magnetic Dash/Window Suction Mount for Mobile Devices Adjustable 360 - Walmart.com
Here is the short USB c cable I use to power it. Clips to the mount as well to keep things in place... Amazon.com
Here is the power adapter I use that can do fast charging since the USB A cables typically can't charge fast enough while using the device and it has 2 ports if you want to charge a phone...Amazon.com
Pic with the new cable...
How can you confirm both engines are running if you don't see the tachs? I don't have engine rpm's on my connext, screen. That is why I put the chart plotter on a ram mount so I can swivel out of the way and see the tachs when I stat.
I can't explain it, and I'm not saying you have a problem, but for some reason, I have stellar hearing at my age, and I notice the sound. The tachs offer visual verification, but I've never guessed wrong, so that's why I don't see them to be as vital to me.
That is a great point, however, and I see the utility of them regarding your point. It's another thing to think through, and address in some fashion, for the time where I start to slip, or the situation that's out of the ordinary from my typical boating. The suction cup mounts can be found with a hinge, so you could flip the tablet up, or more thought could net a better solution... This conversation is exactly what needs to happen, to trigger ideas
With kids in the boat, people talking, etc. music (not Loud) waves, other boat firing up there engines at the ramps, etc. etc. And my hearing is average I guess, hunting and target range have taken their toll a bit, as well as all the loud concerts I went to as a kid. I am not going to risk an engine on sound alone. I always take a visual on the tachs after starting. Also, the Admiral drives once in a while, the kids can drive and do once in a while. Especially when I feel like wakeboarding or tubing, etc. Would love to get them to the point where they could actually launch, dock or load the boat....... ah my dreams are small...... Part of their routine, is to very that that both engines are running. The can be a few things going on when a rider falls of and there are boats around. sometimes you need to come around pretty rapidly to head back toward your rider.. Engines get started and stopped, or can be multiple times while approaching people in the water.
One mistake and I could be out an engine.
Anyhow, I would of liked to remove the tachs or to put them inside the helm and secure them and cut/mod the dash panel to drop in the Chartplotter, but since our boats don't have the tachs on the Connext, that was a no go. I would much prefer having an in dash Chartplotter, and ALSO a Ram mounted tablet and the connext. But having to leave the tachs in I ran out of room. Unfortunately. Would be very cool if everything was NMEA compatible. Hate that Yamaha does their own thing.
Thanks, I will have to check those out
I forgot about your cupholder mount, that's an easy fix too, that's not permanent, but still provides the same result. You had RAM mounts for everything IIRC, which is the mounts I'm 100% sold on, despite the price. They have never failed me in a semi, or delivery truck, which is more than enough proof of their quality.
Going down the path of trying to keep them visible, I know they make gauge clusters for cars that guys use for aftermarket setups, I wonder how much cable is available for something like that, to remove them from that area, but still have them out for ready access ?
Has anyone tried replacing the AR 250 7” connext screen with the 12 inch version or even just a basic touchscreen monitor?
The screen on my Yamaha FSH 210 went dead and there is no eta. Still no luck on anyone making some after market compatible screen?
My plan is to take apart the 7” connext housing on the AR250 (four bolts behind unit). Then have a new housing made that will hold two 7” monitors. Slide the Yamaha connext to one side and add a garmin 7” chart plotter. I spoke to a Yamaha tech, the housing definitely comes apart and the screen is just connected to a harness. My brother in law has a 3d print shop so it’s definitely doable.
