DBamaC
- Hoover, Al
- AR192
I believe the Led part goes on the top not the bottom. If so, I don't think anything would be below the hull causing spray. They do look like a neat idea. I'd be interested to know how they work out as well.Interesting!
19' boats have dual drain plugs that are off to the sides and not in the center so I don't think it would be in the way. However wouldn't the LED part sit below the hull and if so would it create any weird drag or spray?
My underwater lights made about the same diameter circle, but not nearly as bright as that. WowHere is 8000 lumens
The bolt pattern is different also. Not a big deal, just to be awareThey make a 16,000 lumens version! Its a tad more expensive!
https://www.boatpluglight.com/colle...cts/the-mormo-drain-flange-light-16000-lumens
Interesting!
