Has Anyone Upgraded their Shower?
JAUGA82
Birmingham, Al
242 Limited S E-Series
I've decided I'm going to try and add some horsepower to the shower on my 2016 LSE series. It's almost worthless as is...my sink sprayer at home has twice the power. I was thinking about getting a diaphram pump used on many center console sprayers, change out the nozzle, and add a longer hose...maybe even add an intake hose you could drop into the lake to refill the tank. It would be fantastic if I could actually spray down the inside after my kids deposit their usual layer of chip crumbs and Capri-sun juice. Has anyone tried something like this? I would greatly appreciate any pointers.
Sounds like it would be super handy, I’d modify my 212x for one cause I feel ya on the kiddie deposits
Jauga,
The shower on my 2013 Yamaha 242 is absolute garbage as well. It leaks out like a garden hose after its been shut off. I also noticed that when I accidentally left the switch for the pump on it drained my whole tank! Not sure if it is suppose to do that or not. I will go into the system this weekend and figure if i am going to install a high flow pump or to see if there is any kind of low restriction or flow reducing devices somewhere in the lines. Let me know what you end up doing.
I agree that it may not be as functional as it could be. I would bet it will be hard to get any real pressure for a washdown system. Would it be worth looking into what the FSH boats use? Theirs is actually designed for washdown right?
I was doing some searching, and I think I found the perfect upgrade kit for it. I will just leave this photo right here. (discuss)
Did anyone do anything with this? I pee harder than the shower sprays. Would like to see about changing this out. Was thinking just a better/bigger pump
