Brandon neidemire
- SX
Hello boaters.this is my first posting.i found my way here unfortunately cause I just bought a 2013 sx240 and am having problems with the port side engine.I found the 4th cylinder had a stripped spark plug threads and the coil pack was missing half the boot and the bottom of the coil pack burned away..i placed a save a thread Heli coil in it and new coil pack and took it out .got out on water and plug hole was filled with oil.took head cover off and picked out pieces of diminished gasket.installed new gasket, changed oil,took out and ran for 10 min and started losing rpm.slowed down and the engine died.now acts like it's locked up.starter clicks won't turn over.pulled plugs and all look good.no shavings in oil.starter just clicks with plugs in or out.what the heck??? Anyone have an idea? 35 k and nothing but problems with first jet boat.dealer I bought from is floored and said they work with me but don't work on jet boats.anyone have any thoughts? I took to jet boat dealer and they can't get to it for 3 weeks.please someone tell me this isn't a bad engine
