helm dash panel mount studs are glued on to back of bezels :(
AZ_AR195
AR195
fair warning - if you ever have to remove your helm's dash bezels the bolt studs are glued to the back of the bezel. The glue breaks free from the bezel with very little torque ( hand tightening ) when removing and tightening the 9mm nuts. very frustrating. i recommend doing what i did which is using a better 3m panel bonding adhesive before reassembly. do not use hot glue, didn't work for me at all. project turned out nice tho so that makes up for the frustration.
off topic... whats the 2nd to last button, next to the cruise assist?
