Monterro
- Virginia Beach
- SX
Looking to build a mounting bracket for my Weber Q1200. I don't like grilling on the table or swim platform. Bow works best but need to find a way to secure it up front. The Weber bottom is open so there is no way of securing a mount directly to grill. I already have 2 of these grills and I love them. Can't justify the cost of the Magma grills. Here is something I came up with that may or may not work. Looking for any insight on whether I should try to tackle it or not.
I have a Weber stand for the grill. I am thinking of taking the top off of the legs and mounting 1/2" marine lumber to the bottom over the opening. The lumber will be attached to the bottom of the top with some nuts and bolts. I will then attach a Magma level lock to the The grill is able to lock into place on stand and should be able to withhold the boats movement while anchored.
The plastic for the top is only about a 1/4" thick. Do you think it will be able to hold the stress of having the lumber secured to it? Also the grill is approximately 30lbs.
Here is a link to the Magma level lock to attach it to boat.
http://www.magmaproducts.com/Produc...met_Mounts/Single_Mounts/T10-327/t10-327.html
