teisenhart
- Philadelphia, PA
Long time follower, first time posting! Little background, end of last season I sucked up a bunch of sea grass and apparently a shell. First time out this season and I was not able to get above 13mph. Checked to make sure the clean out plug was seated correctly and nothing was lodged in there, it was fine. When I inspected the the pump, I did find a shell in the housing. After removing the shell, I was able to get the boat to go up 48mph however it seems like I’m experiencing some cavitation or possibly bearing issue? It seems like it takes longer to accelerate and doesn’t sound right to me.
I shined a flashlight through the intake grate and felt the impeller. I didn’t fell anything that I thought was too rough or chipped but I’m starting to think the gap between impeller and wear ring is too much. I’ll have to pick up a feeler gauge tomorrow to measure the gap. Are the stock wear rings stainless steel? If so, do I need the whole impeller housing with another stainless wear ring? Best place to order these parts? I read that only buy OEM parts.
I started removing the pump today to inspect further but had to stop because of t-storm. If I find anything else while the pump is completely out, I’ll update! I’m assuming I have to take off the 4 Allen key bolts for the articulating keel in order to pull the pump housing with spline?
Any advice is greatly appreciated!
