cubaniche
- LS
Hi guys. First time post. Bought an LS2000 that had both engines replaced about a year ago. After a little TLC (replacing oil lines, performing compression checks which showed 118-120 on all cylinders, replacing fuel filters, new plugs, installed primers into the fuel lines to manually prime before start, took exhaust apart and broke it down to the three parts and cleaned all the gunk and buildup that was in there and put back together with new oem gaskets, and a few other maintenance items on the boat) both engines start and run. Cooling is great.
The issue I have is with the starboard engine. Its not as smooth as the port and doesnt rev as high as port. Not going to go into too much detail there to prevent mis-diagnosis. Basically, I think I've confirmed that the #3 cylinder isn't achieving combustion. I thought it was spark at first but testing that showd spark arcing if I grounded the spark plug to metal while turning over the engine. I also tried disconnecting the boot from the plug as the engine ran and there was zero discernable change in sound or rpm or anything but if I pulled one of the other two boots off a cylinder (1 or 2) it was definitely noticeable. If I put one of the other wires from 1 or 2 on 3, nothing happens. I started the engine on one cylinder, first on 1 and then on 2 only but when trying 3 only, all it does is turn over. Using one of the other cylinder plug wires results in the same no start using only #3.
Pulled the plug from #3 and its sparkling new, no steel of fuel or anything. The other two, while only a month or so old, have a nice brown/black tinge to them. This is when I tested spark btw and confirmed #3 has spark. If I adjust the low end screw the engine does not respond in any way but if I adjust one of the other two I can get the engine to change rpm.
So, my question to you all is, does this confirm that fuel isn't reaching this cylinder and if so does that make this a carb issue specific to this cylinder and carb? Is there an "easy" way to test this? Like, is it OK to pop the flame arrestor cover off and dribble fuel down into the carb with the oil that dribbles down or would that cause some sort of backfire? I just want to see if I get fuel in there, does the engine respond in any way, and if so, then I know its that carb.
Any help is appreciated!
