jb32566
- Navarre, FL
- Scarab
- 165 ID
What is the other end connected to? Please take more pictures and not so zoomed in.So we're headed back and I noticed that the boat is started to feel swamped and I popped a beached and pop the back and sure enough it looks like we blew a hose need help knowing where to reattach it build seems to be training decentlyView attachment 94283
Regarding the bilge alarm...
I installed a bilge alarm with a cheap 12v buzzer and 2 indicator lights. I could not figure out how to do what I wanted without a relay, so there is one in there. Alarm light and buzzer only come in if the float activates the circuit. if I turn the bilge on manually, and the float is not triggered, there is no alarm. I have 3 bilge pumps total. OEM + 2x Tsunami 1200, which are pretty low draw. In my case, all pumps come on if the float is triggered, and by the water flow and number of holes with water I can tell if the water is going up or not. Best mod for piece of mind. Already saved my prior boat twice, and once for the new owner. On the old boat I just wired the buzzer and light in the circuit with one extra pump, so manual or float, a loud piezo peeeeeee came on, which helped ensure you did not forget to turn the pump off....I called it a feature, but I fixed it for the new (to me) boat.
