Yeary4
Same thing happend to me in my 07. I just took a bolt from the other hinge and found an exact replacement from home depot.So today on the water the hinge and bolt came off the cover for the engine department on Yamaha SX190. Boat is a 2020 so very disappointed. But if anyone can identify the bolts needed to replace (picture attached). Thanks
I’ll do a more thorough check but when I felt under the other one, it felt like there was only one bolt in which makes me think both only had one bolt.I do not remember the size. It was threaded all the way I do remember there were 4 large washers. Did you loose all the bolts from both hinges?
Thanks for the diagram. Helps a lot. Wish it showed size so I can just pick it up at Lowe’s or Home Depot. I’ve googled the part number and can’t find any description from anyone on actual size.Yamaha Boat 2020 OEM Parts Diagram for Deck Hatch 2 | Partzilla.com
Buy OEM Parts for Yamaha Boat 2020 Deck Hatch 2 Diagramwww.partzilla.com
might start here. Looks like the engine hatch hinges are parts 2-5 in the diagram.
I think I remember the bolt being something like 1/4 20 course thread and 1.25 or 1.5 inches long. But that is my model which is an 07.Thanks for the diagram. Helps a lot. Wish it showed size so I can just pick it up at Lowe’s or Home Depot. I’ve googled the part number and can’t find any description from anyone on actual size.
Yes! Thanks. The second ones sizes isn’t listed but assume it’s the same.? Thoughts?If this is the screw you are looking for #4 in the Partzilla link above... https://www.partsvu.com/90149-14sc6...hQee8mqLFFY4Dfoip-6Zx5r7FzUVdAsUaAgxOEALw_wcB
Buy Stainless Steel.
The #3 screw in the Partzilla link is used on most of the model years up to current. SCREW 90149-14SD2-00
Never mind. I see the difference. One is a screw and one is a bolt. Same length.Yes! Thanks. The second ones sizes isn’t listed but assume it’s the same.? Thoughts?
