Help locating this loose bolt
Ando
Los Angeles
Found this laying in the engine compartment and I can't locate where it may have came out from.
2008 Yamaha AR230
Keep looking around the engines you will find where it came from. I had one like that come loose and it held a bracket to the side of the engine.
It looks like it only had about an 1/8th of the threads screwed into whatever it came out of so its something wide that it went through.
Mine was up top by the air cleaners, to the left in the middle holding a bracket
Is the head of the bolt a 14mm or 12mm?
Looks like it's pretty beefy with course threads. Is it possible that's an engine mounting bolt? Check all four feet on each motor to make sure.
My gues is an enging mount bolt...oretty darn important torque can do som hefty damage...i believe there are 4 of these on EACH engine.
@Milwarc mention engine mounts...double check all your mounts. Looks like the bolt under the air case too, but that one would not have come out of the airbox I wouldn't think. Best of Luck!
As large as it is, i would guess engine mount also.
The imprint on the washer should lead you in the right direction
My first thought was also the top of one of the motor mounts
Check the engine compartment hinges in the inside on top be cause it happen to me on each hinge they have to screws.
