Help me Decide
Geiger41
Egg Harbor Township NJ
Boatless
NA
NA
So I have a chance to get a 2023 195s with a tower leftover never used for 40K. 2 year warranty included.
Do I get that or a 2025 AR190. Similar price...
Pros, Cons, thoughts
Dont buy the ar190, you will wish it was the 195. Power difference is key. The 195 has better fit/finish. Better resale,
The 190 is underpowered in comparison to the 195. Same price its a no brainer
What are you going to use the boat for?
Where are you going to use it?
How often are you going to use it?
How many people are going to go out on the boat?
The 195S has 250 hp and requires 91 octane ⛽️. Not all boating areas have 91 octane on the water, if that’s not a problem where you boat then that point is moot.
The AR 190 has 200 hp and requires 87 octane fuel.
@Neutron makes some good points about the fit & finish and about the power. The AR 190 has a power to weight ratio of 13.37:1, and 195S has a power to weight ratio of 10.96:1. So if the go fast thing is super important then the SC 195S is for you.
Here’s a 2020 test of the 195S, pretty much the same boat performance wise as the 2023 model.
The most recent test boat test has of the 190 is from 2019 with the normally aspirated 1.8
Looks like the difference in top speed is 5 mph, 43 vs. 48. The best cruise mpg is 4.5 on the 190, with the 1.8 not the 1.9 the non CA 2025 has, the 195S has a best cruise of 3 mpg, so if you’re going to be running the boat a lot, fuel consumption could be a factor.
Speaking of the California model 1.9Lengine, and the Non California 1.9L engine, there is a post linked below about a person in CA that has a 2024 or 2025 190 with the new 1.9L engine that was unhappy about power, turns out the CA 1.9 model has less horsepower, 154HP / 115 KW, due to emissions which is the four star rating, than the non CA 1.9 which has 200 HP or 149KW. So have a look at the engine and there will be a label on the engine that shows the power output in KW, you’re looking for that 149KW number.
Here’s the post
I have a 2023 AR195 and love it. Agree with Neutron...I wanted the Supercharger being the Gear Head that I am..:)
$40K for a 2 year old boat is a little high but not much.
Actually, the 195S is a slight upgrade from mine...so, that price of $40K seems right.
I think that's the biggest point being missed so far. The 195s not only has the power advantage, but the "s" package gives these boats so many comfort features that have been overshadowed by the motor. Upgraded features all the way around from the base AR190/AR195 models. After owning a 242LS over the base AR240 model, I can appreciate all the features that the LS brings to the table. Yamaha nailed it by offering the "s" models. Check out the differences, and I think they will sell you on the older boat over a new boat without them.
Best of luck, there are no wrong decisions, just better decisions!
While I love my SX190 for 30k, a 195S would be too hard for me to pass up had I been able to get one for 40k. By the time I was done ripping the carpet out, installing Seadek, speakers, amp, some S trim pieces like the gas cap (which was originally a hideous white plastic), chrome cup holder rings, etc. I'm not far off from that.
At MSRP, I'd probably look at a bigger twin engine over the 195S and do the same upgrades again that I had done on the 190. Although you can carry 8 people and their stuff, it's not comfortable, fast, or maneuverable with more than 4. You really don't want anyone in the bow unless it's dead calm. For me and my wife it's a great size. We came from a Seadoo 15' Sportster, so it feels palatial in comparison. As a couple's boat it's about perfect with three different 'zones' for two to relax when anchored.
