Osric
- 242X E-Series
This year I bought the wake wedge from Gantlin Products and the custom fatsac. @jcyamaharider has provided excellent support throughout.
I struggled a bit with installing the brackets. For someone not handy with tools, the positioning of the holes is very demanding. I did it on my boat lift in my boathouse and I recommend if you're drilling these that you get your boat trailered or otherwise on very solid ground so it isn't bouncing around, and use split point 135 degree cobalt drill bits, with oil on them, to drill the holes in precisely the right location. In fact if I had it to do again, I would dispense with the template altogether and clamp the actual bracket in place, test fit the wedge to ensure the pins slide in easily and slide out easily, mark the holes, and then drill.
As it was, I drilled into the bracket with the boat on the lift and all my holes wound up in the wrong spots. I corrected the holes on the goofy side by clamping the wedge bracket in place and drilling through using the bracket itself as a guide, and even so I was off by enough that the wedge is at an angle that prevents the pin going through easily. For now I have put a washer between the bracket and the ladder bracket, but ultimately will probably drill the bracket out so that it can sit flush against the ladder bracket rather than sitting against the washer.
On the regular side, the hole wound up close enough to the ladder bracket's brace that I had to dremel off part of the bolt head to get it in, but the wedge fits fine and the pins go in fine after that.
So we finally got to try it out tonight for the first time. Here's the wave:
The setup was all on-board factory ballast filled simultaneously (meaning they're not as full as they can be filled, if you fill them one by one), fatsac pretty full, family of four on the port side, driver weighing in at about 200 lbs.
The wave looks OK to me but I'm no expert, and my son managed to surf ropeless for the first time on this wave, maintaining it for about 5-10 seconds before losing the pocket. We were traveling at about 18kph (12mph) with the boat at full throttle.
I'd love to make the wave longer and/or hear people's views on the right levels to fill the factory ballast to. I have a 2017 242X E-Series boat.
Thanks in advance!
Thanks in advance!
