Berberman
- Massachusetts
- Other
2022 AR210 here.
Breaking in the engines, on a calm lake, going fairly slow and under 5000 rpms for about an hour, I noticed a good 3 inches of water in the ski locker by the time i got back. None in the engine compartment. When the ski locker is taking on water while under way, which drain plugs do you open to get it evacuated? Also, do you ride with some plugs open?
Help me understand how the water makes its way out of the boat.
a- I have (to be verified as I have not really looked) 1 drain plug in the anchor locker (right?)
b- 1 drain plug in the ski locker
c- 2 drain plugs in the engine compartment
d- and finally 1 drain plug at the back of the boat (by the articulating keel between the two buckets)
