HELP ME!
crains
255XE
I have a 2022 255XE. My speakers just wont produce sounds. Initially I thought Bluetooth had not connected, but the radio would not produce sound either.
I have read a couple of threads here that suggest it is likely the amp. Before I run out and buy an amp, I want to make sure that's what it is, how do I test the amp? Reset the amp? Dare I ask, locate the amp? ?
I would definitely start with the amp. Make sure all connections are good and you have power to the amp. A volt meter on the terminals would be a good start. Check power in and out of amp.
Why would you have to buy an amp for a 2022 boat? Wouldn't it be under warranty? If all speakers are hooked up to the amp, there usually a blue turn on wire for the amp. Sometimes it's fused. I would check that too.
So... went to check the amp... and found this.
Obviously someone felt they needed it more than me.
What's the best amp money can buy?
Where do you store the boat? Just curious how or where it could've happened
Best amp money can buy, or best bang for the buck at a particular price point. As if it were me, the stock systems are not all bad, and there are folks that don't agree with that. I would bet a stock amp could be found from someone replacing theirs. Install would be easy to, as only a few of those wires were cut from your photo.
Find what was used from the factory, and possibly find one online and wire it up. Spending more money on a high end amp without replacing other components may be money wasted. As the stock amp is probably of the same quality as the stock speakers. Was it a wetsounds factory system? If so, you probably had a decent amp in there. (good enough for someone to steal it anyway)
Great insight!
Someone with your model can chime in but I thought it had a wetsounds crippled version. How many speakers?
