David Martin
- Punta Gorda
- SX
Ok OK I know its not funny....most posts are about engine over heats and I am complaining about engines running way to cool. Question what thermostats are available to Yamaha....in my 5.7 and 454 BB you can get any temp/flavor you want in a stat. Heck I can't find temp numbers on Yamaha so finding higher thermostats looks to be daunting at best.
I just got my Blackstone oil report(no real surprises)that would damage an engine) but had fuel(gas) in oil and trace amounts for water........Blackstone report stated since no potassium(I boat in saltwater) they called it an anomaly. After calling them(man they know engines and oil) I told them about how cool my engines ran so it would appear that condensation that normally would vape off is present due to low temp.... Also hotter oil would help the fuel build up from the long idle periods.
A typical day for me is idle out/back is 1:30 min for a 2 hr at speed. That's 6 hours at speed and 5 hours at idle per week. Also my plug read is normal at 73 hours(plugs look great) so that eliminates injectors as the fuel problem........it just long idle time. NO YOU CAN SEE why I need to up engine and oil temp.
I'll post oil report on Yamalube 10w40 mineral, Suzuki 10w40 semi Syn, and my used oil simi syth 10w40 Amazon basic and what the additives all the oils had later. No real surprises on any of these oils.
