andyak
First off I have removed and replaced exhaust gaskets on both engines. The first engine I replaced gaskets on I reinstalled and got everything hooked up started up fine.
Now 2nd engine I got everything hooked up correct - double checked connections and I get no startup joy!
I have pulled plugs that seem dry and verified spark.
I have loosened fuel line and got fuel spray. I went so far as to install backup replacement fuel pump- still seems to have pressure but I do not think fuel is being injected as I get no ignition.
Will Crank forever but no start. Can't smell gas. Other engine starts right up.
Any ideas? I am stumped.
Worked perfect before removal and new collector gasket.
Thanks in advance!!
Andy
Thanks in advance!!
Andy
