@HELP Need to use my Yamaha to tow a stranded boat
Quad
Jetboaters Commander
No Lake, CA
Boatless
NA
[USERGROUP=9]@HELP[/USERGROUP] -
I need to go out and tow in a buddy whose engine blew. I've got a 242SE, where should I attach the tow line? Should I make a bridle going to the two stern cleats? Should I use the ski tow point?
THANK YOU!
Bridle to the two tie downs on the stern.
Ski tow point. Ease into it, go slow.
I would imagine that you would want to use the tie down spot on the transom wouldn't you? I can't imagine a ski tow point would have enough strength to pull THAT much weight (boat).
X2 on Tie downs, pay attention to the tow line at all times.
Rescue successful! We made a bridle to the stern cleats (instead of tie-downs) and pulled him the 3 miles home - all in the midst of a crazy downpour. Fun day!
I wouldn't use the ski tow point....pretty sure it has like a 400lb weight limit. The tie downs are far stronger, and when you attach to two of them, your double your capacity.
I can’t imagine 400lbs is right. Our 3 person tube puts a whole lot more force than that when whipping it around.
If you can, try to wiggle those a bit. Occasionally folks will post that the bolts on the back of the cleats will be/get loosened over time. After that kind of force, may need adjusted or tightened.
Good work! I always say pay it forward.. next time it will be you in need of a tow.
Mine are actually a little loose , how do you tighten the cleats ?
For my front ones, I removed the speakers and stuck my hand up there with a wrench.
Funny, I just went through this on Saturday. But the boat in question was a 30' Cruiser Yacht. There was no way I was tying anything that heavy anywhere (cleats, tie downs, or otherwise) so we opted to just hold onto the dock lines:
Towed it, real slow, for just under a mile. Quite the workout! :D
Whoa!
I was towing a 1990s Donzi BlackWidow 24'. Heavy boat for its size.
Yea, if we had the time, it might've worked better to tow by hand but we were facing a very small window between two of the largest storm fronts we've seen all season and had to high tail it at a speedy 7mph. Engines were running at ~3600rpm to maintain that.
Did the same on Saturday. Boaters code.
The force needed to tow that pontoon was minimal. We took it real slow, there was no hurry.
I tied to the grab handle, as it's stainless and reinforced. Worked just fine. The cleat on our boat was used at one time, and it gave it just enough of a tweak, that it sticks now. I many times have to use a metal object to pop that cleat open. So I don't tow from the cleats anymore. But then again, we don't tow other boats very often either.
Looks like you just brought a party barge along for your day out :D
Ironically, when we got to their lift, the entire area was loaded with surface weeds. Yup, we loaded up the pumps with weeds and overheated.
I untied them, and said, "you have 8 kids on that boat, I would suggest they put on a jacket and swim you into your lift" And then tossed the rope to them. This was after she asks me (lady captain) "can you get us into the lift?" Ya, I will tow you into your lift. Too funny.
Needless to say, I limped my boat out to deeper water and used my cleanout ports for the first time ever to clear weeds. Good thing I rebuilt my cleanout plugs this spring and lube them regularly. I do see the need to inspect these a bit more than just lubing though. There were some weeds wound up in there that may have been causing my cavitation the day before surfing. Hmmm.
Towed a 18ft fishing boat a couple of weekends ago from my ski tow point. Just took it slow and had no problems. 20200806_081605.jpg
