rand01tj
- SX
Of course things love to go wrong when you’re on vacation... Looking for a little help here. 2012 AR240. Having issue getting fuel to the port engine. Only getting 10.5v to the fuel pump connector at the pump when I turn it over. I am getting 12.5 volts at all the fuses on the fuse panel. have tried:
1) checking/replacing all fuses and cleaning all fuse contacts
2) swapping ECU's
3) swapping cleanout hatch sensors
4) swapping both relays to the other engine
5) checking just about every connector in the engine bay.
if I plug in the fuel power connector from the other (starboard) engine to that fuel pump and use it to power the pump by occasionally bumping the (starboard) engine it will run so I know it is not the pump itself.
Any ideas or help would be greatly appreciated. The family is very let down and I would love to be able to salvage the rest of the trip.
does anybody have a copy of a wiring schematic? I found one for a 2015 but it didn’t seem to be the same.
2) swapping ECU's
