Help no power
Van T
Chesapeake va
Have no power to any Electronics but the engine will run but I can't turn on Bilge or accessories none of the gauges will work or anything plugged in to the cigarette lighter something shorted checked all fuses and relays nothing will work is there any fuses on an FSH besides the fuses in the engine bay
[USERGROUP=9]@HELP[/USERGROUP]
Did you forget to hook up a wire on the battery?
Look for an inline fuse near the battery.
More should chime in shortly....
I haven't seen an FSH, but all accessories in many previous yamahas, are protected by a single blade fuse in the battery compartment. It is on the wall. Check that fuse.
Sounds like a blown fuse for the house circuits. In previous Yammi's it's been in the battery compartment near the switches.
@Van T you ever get squared away?
Got it it was next to switchs .black cloud was over us yesterday then the golf cart crapped out. thanks for all the help guys .you can always count on this site to set you straight.
Glad to hear you got it figured out. . . . Safe to assume it was the fuse "next to (the) switches"? Just want to clarify for anyone searching the issue in the future.
Has to be the blade fuse. Happened to me. Now I carry spares on board. Easy fix.
FSH has a 20 fuse near the battery switchs kind of hard to see tucked up under the deck edge time to keep extra fuses on the boat fuse blows no Bilge or any accessories
