Sackman71
- 242 Limited S E-Series
Hello- I have a 2014 Yamaha SX 240 HO. Port engine keep going into limp mode and displaying engine overheat. No obstructions in Impeller, pump or the intake block located on the pump. The temp sensor is located under the intake manifold and is a decent job to get at unless I'm not seeing another way. The plug has no corrosion but is pretty loose. Slides back and forth easily. It overheats on a hose at at low rpm within 1 or 2 minutes. The engine does not seem hot. Can I jump the wires and test the sensor as i do not believe the engine is really hot. In the water the pea holes blow water just fine and both water streams seem to be close in temperature by feel. Unless I'm wrong and it's not a big job I could switch sensors between engines. Any thoughts? Thanks
