Farny
- Spring TX
- Centurion
- Other
Ok - for you Audio experts - couple questions…
* attached wiring diagram is my current thinking and plan (parts on order not started)
Current system:
Stock head unit and speakers
KXM400.2 kicker amp powering
2 Kicker 8” towers (1 speaker each channel)
1 100w RMS powered sub
Adding:
2nd KXM400.2 Kicker Amp
2 more Kicker 8” towers
Blue Sea mini add a battery
Deep cycle Battery XP3000 XSPower
NOCO Genius 2bank 10a charger
Questions :
1- I would like to keep stock accessories on similar power config running inline with stock battery. Run amps and sub from House (audio) battery. This way the ACR charges start stock battery first and the amps don’t drain the stock start battery.. Is my wiring diagram accurate for the power switch and M-acr ?
2 - speaker wiring AMP 1 : plan on running the 4 towers off the 2ch amp. Wire 2 in parallel off ch1 and wire 2 in parallel off ch2. (2ohm capable) should push 100w RMS to each tower. Is this schematic correct?
3 - speaker wiring AMP 2 : I would like to run the stock WetSounds off of the second amp. Does anyone know if the stock speaker wiring system is run in series or parallel?
3a - IF I run the stock WS speakers in series - for each Chanel on the amp - will the [AMP (100w RMS) run to 2 speakers (60w RMS)] blow the speakers? Any suggestions here?
4 - speaker LED’s. Do I have to have individual wire runs for each speaker LED, or can I jump from one LED to the next?
“Proper planning prevents poor outcomes”
Appreciate any advice from you Audiophiles out there!!!
Current system:
Adding:
Questions :
