HELP! Port maintenance required light just came on
Firechic78
Scarab
255 ID
So been running all weekend no problems then today info light on dash came on and says port maintenance required. Everything is running great just concerned what this means. Just had it serviced before summer. Did they just forget to reset computer? Please help. On the water today but if I need to head back and take it out I will. Thanks in advance. HAPPY 4th to everyone.
Canadian here... Happy Canada Day right back at you! lol
The wrench light, presumably the one you're referring to is simply an alarm indicating when maintenance is due. It is entirely based on a number of hours set by the dealer. So yes, the either forgot to set it or didn't set it correctly.
You have nothing to worry about if your maintenance was properly done and on time. Carry on and get it set next time you can.
In the meantime, electrical tape over top of it. ;)
Happy Canadian day! Ok great. Yeah everything I read said the same thing. Thank you so much. I’ll just cover screen with a towel. Hahaha. Hope everyone had a fun and safe weekend.
I have the same issue - full service 15 hours ago but now get the horn every time I first power up. Easy enough to silence, but I was wondering if there is way to cancel this or or does that the dealer to do?
Thanks Scoop
The dealer has to do it. But I was told there is a system out there to clear, read, and tune the BRP equipped boats. Its pricey. CANDooPro LLC, Diagnostic Tools
Hope this helps
OK Thanks. I will just get it reset at the next maintenance.
