Help removing throttle panel
Chaparral
VRX
Trying to fix a ereverse module error I am checking the throttle connections after checking all of the breaker, fuse, relays and other connections. I want to remove the starboard panel for the throttle on a 2019 Vortex 203 VRX but after removing the screws for the plate and a single screw at the back of the panel it still seems attached and I don’t want to break it off.
Any videos or manuals or tips someone can share with me. Just want to check the throttle and lanyard connections then put it all back afterward.
Thanks
