ToesintheSand
- Attica, Mi
- Sugar Sand
- Limited
Holiday weekend at Higgins Lake and I have minimal time to fix this issue. I have 2 dropped cylinders on 1998 Powerjet 175xr2, narrowed it down to coils and switchbox....I think. Spark tested all cylinders and found that two bottom cylinders on left bank are getting no/intermittent spark. One is dead and one gets an occassional spark. Top cylinder is a nice strong blue spark at 7/16 gap so I switched good coil leads from switch box with bad coils to make sure it was coil related. The bad coils did not work with good wires...so I'm figuring 2 bad coils. However, and this part I'm not sure about, I hooked the leads from one of the bad coils, to the good coil.....no spark to good coil. So, is it safe to assume this is the switch box and not the trigger. I say this because each coil on the 3 coiled trigger is supposed to be for 2 cylinders- one on left bank, one on right. Because both my bad cylinders are on the left, I'm deducing that it's possibly a bad switchbox and 2 bad coils. Does this make sense ?? Or maybe it's something eniterly different that I am missing?
This motor runs and moves along ok, but I know it's supposed to be close to 50mph so I started checking stuff and this is what I found. Had I known Iknown i was only running on 4 cylinders I would have never kept driving it.
