Christy
- Grapevine Lake, Tx
- Tige
- Other
Here's back story -
@Detonate has been working on rewiring our entire boat. He took off the tower and had a problem with a screw/bolt that broke off. We took the part with the broken off screw to our friend with a medal shop to remove the screw and rethread the hole. When we got the part back it was missing the rubber gasket. Eeek!
So, what we need are to replace the part. It's part number is F1C-U752C-00-00 and it's labeled 4 in the attached image.
So, the question are:
1) Do you know of any part suppliers that can get it to us by Friday?
2) Do you have any ideas on where we can get a small sheet of uncut rubber to use as an alternative?
