Help- Wiring questions 242
Skysurfer2010
Philly
242 Limited S E-Series
I'm ordering wetsounds rgb revo speakers for my new 242SE. I have two questions in regards to the rgb wiring loop:
- is it possible to do one full continuous loop around the entire boat? I'd like to start at the batteries at port and run to the port stearn speaker, then cross over to the starboard stern speaker, up towards the bow on starboard side and then cross through the anchor locker (?) area to the port side speaker and end there.
I guess my only question is if its possible to run wire from the starboard speaker area through the bow (anchor locker?) to the port bow speaker? Any issues to be aware of? No boat here currently to check.
- I'm thinking 60' of wire should be more than enough for this loop? I'll order 75 just to be safe.
I included a very crude picture of what I want to do.
You can get wires across the bow area behind the anchor locker, there plenty of room. You can get access to it easily by crawling into your ski locker, or new getting a kid to crawl in there. :D
