CoyoteTango
- Other
- Other
- Jet Ski
- PWC
I just bought a 88 kawi and for one im slightly confused as to what size of engine it is. The tittle says modle BT witch hasn't helped me at all. Also it was sitting for 2 years outside and ran just fine before that. im just curious as to what things I should be replacing or checking on before I try for a start up. I came without a battery so im working on getting that. also should it have a piece of wire that attaches to you so that when you fall off it kills it? im not seeing it and im not seeing where it would go. Just any general info about this PWC would help. Thank you!!!
