DeezKnots
Hey folks,
I pulled the boat out of storage yesterday and went about de-winterizing it with an oil change and new plugs. When I put it away last winter I added Stabil to the half a tank of gas that was in it, put the battery on a battery tender, but I didn't fog the motor or anything (dumb new owner).
Anyway, went to start it to warm up the motor, and after a bit of chugging is started up. Running a little rough for a few seconds so I goosed the throttle a little bit and it abruptly stopped with a loud metallic ping. That's when I started craping bricks... the starter couldn't even turn the motor after that (even with a jump on the battery).
So, assuming there might have been some water condensation in the gas tank that got into the fuel line I pulled all four plugs, and there was water on the 3 and 4 plugs. Even with the plugs off and the injectors disconnected the starter just made a high pitch whining sound (I was trying the "let the starter motor blow it out" method). With the motor not cranking I used my (clean) oil extractor pump and just pumped out each cylinder. Tons of water/gas dilution came out of three and four, and a little came out of one and two.
So:
1. How screwed do you think I am?
2. It could be that the motor will turn now, but I might need to check the fuses for the starter / replace the starter.
3. What else should I be doing to figure this out?
4. How much does a brand new engine cost?
Thanks!
So:
Thanks!
