Seattle-Wind
I have a problem with my Speedster 150 4-Tec 155hp that doesn't make sense and I need your expertise. I'm getting a P0616 code and check-engine light continuously beeping, but only when I go above about 5,000 RPM.
This code is apparently for "Starter relay short to ground or open circuit", but the boat starts without issue and shows no code or check-engine light at start-up. The code doesn't seem to match the symptoms.
The code and check engine light resets itself after shutting off the boat, but will reappear the next time it's running above around 5,000 RPM.
The boat is running fine otherwise and I notice no performance issues.
Has anyone run into this before? I checked my fuses and those appear good. Voltage at the rectifier and battery were tested and appear normal.
Could my ECU simply be going bad and it's throwing false codes?
