Help!
Kennytwo
Keystone Heights, Florida
X
throttle won’t engage in forward it’s like it’s stuck please help if you have any ideas it’ll go in reverse but not forward
check bucket and top linkeage. Sounds like rock or something is stuck in there.
Well you couldn't move the top bucket by hand anyhow. Something is binding the linkeage up there on top I bet. or something is stuck in the bucket somewhere
Can you pull up on the bucket while trying to shift forward? Is it one or two engines?
I can pull the bucket into reverse. It’s a 212x so two motors. I’m probably 5 miles to the boat ramp. If I have both motors cranked do I still need to go idle speed to limp in?
I don't understand what you are asking. "Motors Cranked doing what? Going forward?
Can't you get to a beach area where you can get out and look at the buckets in clear water?
Were you using reverse before this happened/ usually things float into the pump recess and lock up the reverse buckets you can actually release the clip where the cable attaches to the bucket and free that then work the bucket loose but be sure to return the cable the same way it came off.
Boat US is great to have in a situation like this, if you couldn't free up the bucket. for a couple hundred bucks a year they would of towed you and the family to safety if needed.
Towing on the water,
Jump Starts,
Fuel Delivery
Soft Ungroundings
Buy Towing Today - BoatUS
