Englewoodcowboy
Jetboaters Commander
- Ceres, VA
- X
I have been tagging along in a few other threads with my ballast questions and ideas. To date I have purchased the Eight 3 CTN 800 plug and play bag (it does not have the red pop up port). It fits closer to the 190 series boats rear under seat storage area. I don't think it will fill to its full capacity but if it does follow the contours of the boat and it can bellow out a bit it will certainly hit the 750 mark if not the full 8oo if the bags can conform a little. Today I ordered 10' battery cables and a bossman 3/8 junction block ($6.00 on Amazon) for the grounds. I am relocating the battery to under the pass side console to clear the way for the bag. With this set up I could automate it down the road if I wanted or easily flip the bag to the driver side for goofy surfing or to the ski locker for wake boarding, which is probably what I will do since we are only talking 1 bag to deal with for wake surfing or wake boarding. The only real modification beyond moving the battery is also relocating the fire extinguisher to the top of the ledge it was attached too and trimming the screws from the rub rail towards the stern, I think I had to trim 8 of them and they are grouped 2 together. I am looking for grey/black cloth that matches what the factory used to cover the screws with, even though they have been smoothed I want a little more chaff protection. Pictures will follow as parts arrive. Total expense of the ballast was just under $300 but I later added the fly high check valve ($39.00) from Wake Makers to try to help keep the water out of the compartment. Custom battery cables by BestBoatWire.com is $50 shipped. Once I source the material and a can or two of 3M contact adhesive this mod will be done.
