The horn, yes. the stereo remote on the swimdeck, no. I had to replace the horn in my previous SX230 after 7 years. As for your remote, I wonder if something just got disconnected.
Yes, my horn goes out annually. I just keep an air one nearby now. Someday I will buy a real horn with which to replace it.
The swim deck remote is always problematic. The connectors leak and I think mine developed a leak in the whole unit. I finally unplugged the whole thing. For the 2 times I think I have ever adjusted anything with it, the shorts and freaky operation (volume increasing wo/touching anything, won't turn off, etc.) of the HU due to it just were not worth it.
I replaced my horn with one from west marine. It is loud and it always works. The 2010s had a problem with the rear remote going out. Mine finally did last year but we rarely used it so it wasn't a problem.
I will have to look to see if I have the exact part number. I did have to widen the exiting hole a little but the horn was about the same size. I will look tonight to see if I kept the part number.
So, I was a victim of Amazon's anniversary this week. One of the deals they showed me was for a Wolo stainless steel set of horns. It was like $73, which was a good price (I checked), so I ordered it. Today, this came:
I included the paper in the photo to provide some scale. These suckers are HUGE! I wasn't planning on something that big. They only looked small in the picture...
Anyway, my original plan was to mount these over the existing horn port (leave the existing grate there and just run the wires out the side of it). However, with the size of these, we will have to see what I come up with...
Wiring is not completely tied up (I have my amp out right now, so when I get that back in I will tie up these wires, too). But basically I unplugged the wires from the horn and pulled them aft out of the casing until I had enough to reach the new forward position.
Note how close I am to the helm space there. Another inch aft and I would have been having a difficult time. Good thing I planned it as I did. Er...
One other note is that I was not able to use the hardware that came with the horns. The bolts were too short to fit through the fiberglass. I drilled a hole just above the aft bracket on the horn for the wiring; sealed that up with 4200.
