zrated512
- Frisco, Tx
Stereo folks; I have an issue with my house battery drawing to much and drawing my battery. Only seems to happen when my sub amp is cranked and continual base.
my question I guess, is anyone of you that have big stereos that draw some power how are your batteries synced? Did you have to add a third battery? If you did, how do you have it hooked up?
My amps consist of the following:
1 wet sounds syn 6 amp hooked up to 6-6.5” wetsounds recon
1 wet sounds syn 2 amp hooked up to 4 bullet high point towers
1 600.1 JL hooked up to 2 10” w3v3 subs.
my sub seem to draw the voltage drop. My boat is a 2018 AR 240 with factory interstate batteries....
