sastocky
- Ohio
We are planning to tie up regularly to this 1989 Summerset Houseboat white it is at dock with our 2021 AR250. As you can see there is not much meat for the Yamaha to push against which is my concern.
I was thinking 2 or 3 Taylormade Transom Fenders to push against the houseboat stern steps. Then tie off the mid cleat on the Yamaha to the Houseboat railing keep it from spinning.
I have also conserved using one of the stiff docking rods or tethers to keep the boat 12” away from the houseboat. These would be tied off to the rear cleats or transom eyes but would need to be triangulated to keep the boat from spinning.
There are houseboats on each side of us that are longer so this is the only way we can boat to boat tie up.
Surely one of you have done this…probably a thousand times.
