Geoff Cooper
- Thailand
10 years old it gets the same treatment about every 12 months when the rainy season comesLooks brand new!!
I've always heard the bleach breaks down the nylon, decreasing it's breaking strength. Maybe not a big deal for dock lines, but I'd be wary if it were my primary anchor line.
10 years down the road and looks ok to me, I don't mean 100% bleach solutionAgree, I'd be hesitant to use bleach on anything that requires strength. Bleach will break down pretty much anything.
There are many ways of cleaning it successfully i have used this method for years and i only do it about once a year, Good to hear from you again long time thought you had forgotten my posts.Another idea we used to do when racing off road MX with our pants and jersey. Throw the rope in a 5 gallon bucket with some detergent and water. Put the lid on the bucket and leave the bucket in your boat on the trailer while you trailer the boat. The bouncing and jostling of the trailer agitates the soapy mix while you drive. Rope should come out pretty clean and won't harm the rope.
You heard right...sorry to be a wet blanket here, but while bleach may make lines look nice, it's not good for them. As a long time sailor I can tell you, we rely and lines to sail the boat and they are a top priority when time comes to put the boat away. The lines we used on our racing sloop were damn expensive, we had thousands of dollars worth. I would never clean them with anything remotely caustic.
Here is a link to an article on caring for rope published in Practical Sailor:
http://www.practical-sailor.com/issues/37_7/features/clean_rope_10509-1.html
An excerpt:
• Bleach is not recommended by any manufacturer in any quantity. Every manufacturer has faced claims of rope failure or splice failure caused by a bleach overdose. Extended soaking in bleach solutions must be avoided
I personally rinse them or soak them in clean, fresh water and dry in sunlight - then coil and put away out of the sun once dry. The sun typically kills anything growing - if you've let that happen, but as the article states; mold or mildew won't weaken synthetic lines. Take care of your lines and they will do the job you need them to.
My solution is to use black lines.
Please don't take my reply the wrong way. I certainly meant no offense. If what you do works for you then keep on doing what you do.
The thing is, not all lines are made the same way and out of the same materials. And what could be harmless to one could cause damage to another.
Clearly, from your photos, you aren't washing a Spectra or other high tech line and it looks like a pretty stout braided line as well. Most of the typical anchor lines are three strand nylon in various sizes and strengths.
If someone were to soak a nylon line in bleach often, over time they could be in for a rude awaking one day. The working load will diminish simply because nylon degrades from exposure to strong oxidizing agents.
All I ever recommend is following a manufacturer's recommendations for their different products.
