Thanks
@Coult45
Firstly, according to the manual the fuel tank in the 210 FSH has a capacity of 52 gallons and not 50 as was shown on the web site and app pages.
Second, a boat, our boats are always moving and are rarely level, so where your standing to where and what load you have on the boat makes an impact on what the percent fuel gauge reads, it’s a boat not a car.
Thirdly, when the diameter and length of the fuel line is taken into account, how a fuel pump at the station might work in regards to how it clicks off, and the angle of the boat (as
@TeenGee mentions) there could be a variability in the fill up of several gallons at fill up.
@ShireRider are you getting your fuel at the same pump / station each time you fill up?  Looks as if the amount of fuel you fill up you have mentioned on two occasions has been high.
I’ve run my boat down very low on fuel once so I would know how much useable fuel there was in the tank, it was so low that whilst idling at the dock the starboard engine shutoff, but the starboard engine re started when on the trailer. I think the fuel gauge read 1 or 2%. When I filled the tank up it took almost 52 gallons, and I didn’t keep clicking the pump handle. Conclusion is that at best cruise on calm water, in the 25-27 mph range almost all if the fuel is useable.
As
@TeenGee eluded to, there is a fuel used monitor in the connext screen, it’s the icon that looks like a flattened U shape at top screen tray, it is digital and reads to 10ths of a gallon.  This particular screen has other readings as well, avg mpg, max speed, avg speed (I think), gph, and total engine hours, and this screen is resettable (with the exception of total engine hours) and of course must be re set to utilize those functions.  I have found that without exception the fuel used gauge is accurate to within 1-2 10ths of a gallon in the total amount of fuel used 99% of the time it is accurate to 1/10th of a gallon and only once was it off by 2/10th’s of a gallon at fill up.  So, let this fuel used meter be your guide at fill up to know how many gallons of fuel should be required to fill the tank up, and how much fuel you have left in the tank whilst on the water, for me it’s fill at the slowest set and forget rate on the pump handle until it clicks off, wait 15 seconds and then one more try with the pump handle until it clicks off again. Just filled up day before yesterday, connext screen showed 36.0 gallons used, the fill up using the aforementioned method clicked off at 35.5 gallons, then second attempt brought it up to 35.949, so pretty damn accurate.
The risk you run with continuing to top off your tank is getting fuel into the carbon canister on the vent line,  if enough fuel gets in there the vapors cannot vent through the canister and will result in a very slow fill experience at the pump. For example, if you put in enough fuel to where the fuel level is right there by the cap the fuel level in the fill hose is above where the carbon canister is and
could cause liquid fuel to fill the carbon canister. Not flaming you
@TeenGee just stating what
could happen.  Having said that,
@TeenGee was crafty in putting the nose of the boat down which puts the fuel fill hose inlet and vent fittings on the high side and lets the tank completely fill as it eliminates any air pockets in the tank, kinda reminds me of how I fill my dirt bike tank before a really long ride, I sort of burp the tank by rocking it back and forth on the center stand after it’s full.
The percent full fuel gauge on my boat is relatively accurate and is a good gauge to read at a glance while underway but my go to is the fuel used meter.  Now that I think about it I’ve only seen my percent gauge read 90% once or twice, I’ll echo what
@Coult45 said, it always seems to drop to 86% or so.
The last thing I’ll mention is that some of the boats with 40 gallon tanks were having issues with the percentage gauge being off wildly, running the tank down low before refilling fixed that problem.
@ShireRider was this the first time you have run the tank down into the 20% range?
