- Rosebud, Mo
- 242X E-Series
There are three main ways I have seen it done. One is to set the tip of the board on the back of the boat and hop on to it. Not recommended for beginners of course. Two is to start with the board sitting flat on the water with your heels on top of it facing the boat. As the boat pulls, you push down on your heels and then balance on the board pushing just enough with your legs to keep the board on plane until you are out of the water. The third method which I employ is a little trickier for the driver. I get behind the boat with the board and while the driver is idling forward get both my feet on the board similar to the positioning of a wakeboard, then have to signal the driver to go immediately because the idling forward of the boat quickly pushes me too far outside. As the boat starts going, I find I pop right out of the water. Personally I found method three easier than method two, and have not tried method one. Your best bet is to youtube some surfboard starts. I think you will find that option two is the most popular. Your boat doesn't have a tower which will make it a little more of a challenge. I would get a dedicated wakesurf rope that only has a knot on the end and not a handle. Most ropes are 15-25 feet long. If your going from a cleat or tube tow point then you might need less length.I bought a wakeboard at the end of the year last year, however, this looks really fun. Stupid question, how do you get up on the surfboard? it seems like it would be really hard without boots to keep you attached to the board.
