xoomer
- Cape Coral, Florida
- SX
I finally got around to changing the oil today in my SX 240 and sucked out a little over 4 quarts from each engine, plus there was a bit in the oil filters. However, when I look at the owner's manual it says:
I would be able to answer my own question if I could read the dip stick--is there a "full" indication? The only thing I see is that it has a bend but normally the oil is above that level.
Engine oil quantity 4.55 quarts
Engine oil quantity with oil filter replacement 3.28 quarts
I'm not sure what the difference is so I just poured back in 4 quarts for each engine--don't know if that is too much or not enough.Engine oil quantity with oil filter replacement 3.28 quarts
