- Raleigh, NC 27614
- 242X E-Series
In the event you have an over heating situation one of the things you will want to check in the cooling water intake strainer. You can see in this photo where the water enters the strainer inside the pump:
Here is the parts schematic of where the strainer is located on the pump:
Part numbers 10-14 below are what come off when you remove the 4 bolts holding the strainer on.
You can just see the strainer on the side of the pump in this photo:
Simply undo the 4 bolts, remove the cover plate and pull out the strainer. Clean as needed and replace.
